string::trimStartFunction in std::string
Remove whitespace from the start of a string.
Whitespace is defined by Unicode's White_Space property and includes
spaces, tabs, newlines, and non-breaking spaces. Only the contiguous
whitespace at the start is removed; whitespace inside or at the end of the
string is preserved.
The start is the beginning of the string's character sequence, independent of how the text is displayed. If the input is empty or contains only whitespace, this returns an empty string. Unicode normalization and case conversion are not performed.
text | string | The string to trim. | Yes |
string - A sequence of characters
