loftFunction in std::sketch
Create a 3D surface or solid by interpolating between two or more sketches.
sketches | [Sketch or [Segment; 1+]; 2+] | Which sketches to loft (or segments, for surface lofts). Must include at least 2 sketches. | Yes |
vDegree | number(_) | Degree of the interpolation. Must be greater than zero. For example, use 2 for quadratic, or 3 for cubic interpolation in the V direction. | No |
bezApproximateRational | bool | Attempt to approximate rational curves (such as arcs) using a bezier. This will remove banding around interpolations between arcs and non-arcs. It may produce errors in other scenarios. Over time, this field won't be necessary. | No |
baseCurveIndex | number(_) | This can be set to override the automatically determined topological base curve, which is usually the first section encountered. | No |
tolerance | number(Length) | Defines the smallest distance below which two entities are considered coincident, intersecting, coplanar, or similar. For most use cases, it should not be changed from its default value of 10^-7 millimeters. | No |
tagStart | TagDecl | A named tag for the face at the start of the loft, i.e. the original sketch. | No |
tagEnd | TagDecl | A named tag for the face at the end of the loft. | No |
bodyType | string | What type of body to produce (solid or surface). Defaults to "solid". | No |
