getBoundedEdgeFunction in std::sketch
Get a bounded edge of a surface used for the blend operation. A bounded edge is a reference to an existing edge that can be clipped at both ends. This will result in only the non-clipped portion of the edge being used during the blend.
solid | Solid | The solid that the edge belongs to. | Yes |
edge | Edge or any | The edge to bound. This can be a tagged edge, an edge ID from edgeId(...), or an edge reference object. Edge reference objects use sideFaces, e.g. { sideFaces = [faceTag1, faceTag2], endFaces = [...], index = 0 }. | Yes |
lowerBound | number(_) | A lower percentage bound of the edge, must be between 0 and 1 inclusive. Defaults to 0. | No |
upperBound | number(_) | A upper percentage bound of the edge, must be between 0 and 1 inclusive. Defaults to 1. | No |
BoundedEdge - A bounded edge of a solid.
