string::toString
string::toStringFunction in std::string
Convert a number to human-readable text.
Defined for every number value, including the non-finite ones.
ValueResultWhy
12"12"no units, so no suffix
1.5"1.5"never rounded
0.1 + 0.2"0.30000000000000004"no digits are dropped
-7"-7"
-0"0"the sign of zero is not kept
3_"3_"a count keeps its _
12mm"12mm"a concrete length keeps its suffix
12cm, 12m, 1.5in, 2ft, 3yd"12cm", "12m", "1.5in", "2ft", "3yd"every length unit does
90deg"90deg"a concrete angle keeps its suffix
1.5rad"1.5rad"both angle units do
2mm + 10mm"12mm"arithmetic that keeps its units
2mm * 10mm"20"units no longer tracked, so none is shown
1 / 0"Infinity"
-1 / 0"-Infinity"
0 / 0"NaN"
1mm / 0"Infinity"a non-finite value never carries a unit
The output is meant to be read, not parsed. Some results are not valid KCL source and reading one back is not supported.
numnumberThe number to convert.Yes
string - A sequence of characters
