cloneFunction in std
Clone a sketch or solid.
This works essentially like a copy-paste operation. It creates a perfect replica at that point in time that you can manipulate individually afterwards.
This doesn't really have much utility unless you need the equivalent of a double instance pattern with zero transformations.
Really only use this function if YOU ARE SURE you need it. In most cases you
do not need clone and using a pattern with instance = 2 is more appropriate.
A clone inherits all transforms already applied to the source geometry. Because of a known rotation-origin bug, rotating a clone of an already-translated body can also move its inherited placement. Until that bug is fixed, clone an untransformed seed, rotate it first, and then apply that instance's complete translation.
// Clone an array that includes an imported geometry, solid and sketch.
geometries | [Sketch or Solid or ImportedGeometry; 1+] | The sketch, solid, or imported geometry to be cloned. | Yes |
