extrude
extrudeFunction in std::sketch
Extend a 2-dimensional sketch or individual segment of a sketch through a third dimension to create a new 3-dimensional volume or surface, or if extruded into an existing volume, cut into an existing solid.
You can provide more than one sketch to extrude, and they will all be extruded in the same direction. Plane-based sketches have no parent body, so each produces a separate body; MERGE does not combine them. Use union when one body is intended.
When you sketch on a face of a solid, extruding extends or cuts into the existing solid, meaning you don't need to union or subtract the volumes. You can change this behavior by using the method parameter. See sketch on face for more details.
sketches[Sketch or Face or TaggedFace or TaggedEdge or Edge or Segment or any; 1+]Which sketch or sketches should be extruded. Experimental face API: edge specifier objects ({ sideFaces = [faceTag1, faceTag2], endFaces? = [...], index? }) are not ready for generated or user-facing KCL yet; prefer existing sketch, face, tagged face, tagged edge, edge, or segment forms until point-and-click and migration support ships.Yes
lengthnumber(Length)How far to extrude the given sketches. Incompatible with to.No
toPoint3d or Axis3d or Plane or Edge or Face or Sketch or Solid or TaggedEdge or TaggedFace or anyReference to extrude to. Incompatible with length and twistAngle. Experimental face API: edge specifier objects ({ sideFaces = [faceTag1, faceTag2], endFaces? = [...], index? }) are not ready for generated or user-facing KCL yet; prefer existing point, axis, plane, edge, face, sketch, solid, or tag forms until point-and-click and migration support ships.No
symmetricboolIf true, the extrusion will happen symmetrically around the sketch. Otherwise, the extrusion will happen on only one side of the sketch.No
directionPoint3d or Edge or TaggedEdge or Segment or anyIf specified, will extrude in this direction instead of the sketch plane normal. If an edge is being extruded, this defaults to halfway between the faces on either side of the edge.No
bidirectionalLengthnumber(Length)How far to extrude opposite the primary extrusion direction. Only used with length; incompatible with symmetric.No
tagStartTagDeclA named tag for the face at the start of the extrusion, i.e. the original sketch.No
tagEndTagDeclA named tag for the face at the end of the extrusion, i.e. the new face created by extruding the original sketch.No
draftAnglenumber(Angle)Experimental. Positive draft angle means the sketch gets smaller while extruding, i.e. inwards draft. Negative draft angle means the sketch gets bigger while extruding, i.e. outwards draft. Defaults to zero, i.e. no draft.No
twistAnglenumber(Angle)If given, the sketch will be twisted around this angle while being extruded. Incompatible with to.No
twistAngleStepnumber(Angle)The size of each intermediate angle as the sketch twists around. Must be between 4 and 90 degrees. Only used if twistAngle is given, defaults to 15 degrees.No
twistCenterPoint2dThe center around which the sketch will be twisted. Relative to the plane's origin. Only used if twistAngle is given, defaults to [0, 0] i.e. plane origin.No
methodstringThe method used during extrusion, either NEW or MERGE. NEW creates a new body. MERGE updates the parent body when extruding a face or a sketch on a face; it does not combine separate plane-based sketches. The default is MERGE.No
hideSeamsboolWhether or not to hide the seams between the original and resulting object. Only used if a face is extruded and method = MERGENo
bodyTypestringWhat type of body to produce (solid or surface). Defaults to "solid".No
[Solid; 1+]
