appearance
appearanceFunction in std::solid
Set the appearance of a solid, imported geometry, or plane. This does not work on sketches or individual paths.
This will work on any solid, including extruded solids, revolved solids, and shelled solids. For planes, only color is used.
solids[Solid; 1+] or ImportedGeometry or PlaneThe solid(s), imported geometry, or plane whose appearance is being set.Yes
colorstringColor of the new material, a hex string like '#ff0000'.Yes
backfaceColorstringBackface color of the new material, a hex string like '#ff0000'. Applies to solids and imported geometry.No
metalnessnumber(_)Metalness of the new material, a percentage like 95.7.No
roughnessnumber(_)Roughness of the new material, a percentage like 95.7.No
opacitynumber(_)Opacity. Defaults to 100 (totally opaque). 0 would be totally transparent.No
Rendered example of appearance 10
