string::isEqualFunction in std::string
Compare two strings for equality.
By default, this performs an exact, case-sensitive comparison equivalent
to the == operator. Set caseInsensitive to true to compare using
locale-independent full Unicode case folding.
Full case folding may expand characters; for example, Straße and
STRASSE compare as equal. The exact mappings follow the Unicode data
bundled with KCL.
Unicode normalization is not performed. Canonically equivalent strings with different representations therefore compare as unequal. Empty strings are valid inputs, and comparison is symmetric.
This function always returns a Boolean predicate, including inside a sketch block. It does not create an equivalence constraint.
text | string | The string to compare. | Yes |
to | string | The string to compare text with. | Yes |
caseInsensitive | bool | Whether to compare using locale-independent full Unicode case folding. | No |
bool - A boolean value.
