yLineFunction in std::sketch
Draw a line relative to the current origin to a specified distance away from the current position along the 'y' axis.
This is part of sketch v1 and is deprecated in favor of sketch-solve. Legacy sketch functions cannot be used with constraints; strongly prefer solver::line with horizontal or vertical constraints inside a sketch block instead.
lengthnumber(Length)How far away along the Y axis should this line go? Incompatible with endAbsolute.No
endAbsolutenumber(Length)Which absolute Y value should this line go to? Incompatible with length.No
