gdt::annotationFunction in std::gdt
GD&T annotation for attaching manufacturing text to faces or edges.
annotation | string | The annotation text to display. | Yes |
faces | [TaggedFace; 1+] | The faces to be annotated. | No |
edges | [Edge or any; 1+] | The edges to be annotated. | No |
framePosition | Point2d | The position of the annotation relative to the leader arrow. The default is [100mm, 100mm]. | No |
framePlane | Plane | The plane in which to display the annotation. The default is XY. Other standard planes like XZ and YZ can also be used. The annotation may be displayed in a plane parallel to the given plane. | No |
