involuteCircular
involuteCircularFunction in std::sketch
Extend the current sketch with a new involute circular curve.
This is part of sketch v1 and is deprecated in favor of sketch-solve and the gear module. Legacy sketch functions cannot be used with constraints; strongly prefer the gear module when it applies. No constraint-based involute is available yet; first try approximating the shape with one or more constrained arcs.
anglenumber(Angle)The angle to rotate the involute by. A value of zero will produce a curve with a tangent along the x-axis at the start point of the curve.Yes
startRadiusnumber(Length)The involute is described between two circles, startRadius is the radius of the inner circle. Either startRadius or startDiameter must be given (but not both).No
endRadiusnumber(Length)The involute is described between two circles, endRadius is the radius of the outer circle. Either endRadius or endDiameter must be given (but not both).No
startDiameternumber(Length)The involute is described between two circles, startDiameter describes the inner circle. Either startRadius or startDiameter must be given (but not both).No
endDiameternumber(Length)The involute is described between two circles, endDiameter describes the outer circle. Either endRadius or endDiameter must be given (but not both).No
reverseboolIf reverse is true, the segment will start from the end of the involute, otherwise it will start from that start.No
Rendered example of involuteCircular 0
