patternTransform
patternTransformFunction in std::solid
Repeat a 3-dimensional body or imported geometry, changing it each time.
Replicates the 3D solid or imported geometry, applying a transformation function to each replica. Transformation function could alter rotation, scale, visibility, position, etc.
The patternTransform call itself takes a number for how many total instances of the shape should be. For example, if you use a circle with patternTransform(instances = 4, transform = f) then there will be 4 circles: the original, and 3 created by replicating the original and calling the transform function on each.
The transform function takes a single parameter: an integer representing which number replication the transform is for. E.g. the first replica to be transformed will be passed the argument 1. This simplifies your math: the transform function can rely on id 0 being the original instance passed into the patternTransform. See the examples.
The transform function returns a transform object. All properties of the object are optional, they each default to "no change". So the overall transform object defaults to "no change" too. Its properties are:
  • translate (3D point)
    Translates the replica, moving its position in space.
  • replicate (bool)
    If false, this ID will not actually copy the object. It'll be skipped.
  • scale (3D point)
    Stretches the object, multiplying its width in the given dimension by the point's component in that direction.
  • rotation (object, with the following properties)
    • rotation.axis (a 3D point, defaults to the Z axis)
    • rotation.angle
    • rotation.origin (either "local" i.e. rotate around its own center, "global" i.e. rotate around the scene's center, or a 3D point, defaults to "local")
NOTE: Currently,, revolved bodies don't support being scaled in a non-uniform way (i.e. scaled differently along each axis).
solids[Solid; 1+] or ImportedGeometryThe solid(s) or imported geometry to duplicate.Yes
instancesnumber(_)The number of total instances. Must be greater than or equal to 1. This includes the original entity. For example, if instances is 2, there will be two copies -- the original, and one new copy. If instances is 1, this has no effect.Yes
transformfn(number(_)): { }How each replica should be transformed. The transform function takes a single parameter: an integer representing which number replication the transform is for. E.g. the first replica to be transformed will be passed the argument 1. This simplifies your math: the transform function can rely on id 0 being the original instance passed into the patternTransform. See the examples.Yes
useOriginalboolIf the target was sketched on an extrusion, setting this will use the original sketch as the target, not the entire joined solid.No
[Solid or ImportedGeometry; 1+]
