bezierCurveFunction in std::sketch
Draw a smooth, continuous, curved line segment from the current origin to the desired (x, y), using a number of control points to shape the curve's shape.
This is part of sketch v1 and is deprecated in favor of sketch-solve. Legacy sketch functions cannot be used with constraints; strongly prefer constraint-based sketch functions when possible. No constraint-based Bezier curve is available yet; first try approximating the shape with one or more constrained arcs.
control1 | Point2d | First control point for the cubic. | No |
control2 | Point2d | Second control point for the cubic. | No |
end | Point2d | How far away (along the X and Y axes) should this line go? | No |
control1Absolute | Point2d | First control point for the cubic. Absolute point. | No |
control2Absolute | Point2d | Second control point for the cubic. Absolute point. | No |
endAbsolute | Point2d | Coordinate on the plane at which this line should end. | No |
tag | TagDecl | Create a new tag which refers to this line. | No |
