Std Sketch PatternCircular2d
patternCircular2dFunction in std::sketch
Repeat a 2-dimensional sketch some number of times along a partial or complete circle some specified number of times. Each object may additionally be rotated along the circle, ensuring orientation of the solid with respect to the center of the circle is maintained.
sketches[Sketch; 1+]The sketch(es) to duplicate.Yes
instancesnumber(_)The number of total instances. Must be greater than or equal to 1. This includes the original entity. For example, if instances is 2, there will be two copies -- the original, and one new copy. If instances is 1, this has no effect.Yes
centerPoint2dThe center about which to make the pattern. This is a 2D vector. If not given, defaults to [0, 0].No
arcDegreesnumber(Angle)The arc angle (in degrees) to place the repetitions. Must be greater than 0.No
rotateDuplicatesboolWhether or not to rotate the duplicates as they are copied.No
useOriginalboolIf the target was sketched on an extrusion, setting this will use the original sketch as the target, not the entire joined solid.No
[Sketch; 1+]
