polygon
polygonFunction in std::sketch
Create a regular polygon with the specified number of sides that is either inscribed or circumscribed around a circle of the specified radius.
This is part of sketch v1 and is deprecated in favor of sketch-solve. Legacy sketch functions cannot be used with constraints; strongly prefer solver::line segments inside a sketch block instead.
sketchOrSurfaceSketch or Plane or FacePlane or surface to sketch on.Yes
radiusnumber(Length)The radius of the polygon.Yes
numSidesnumber(_)The number of sides in the polygon.Yes
centerPoint2dThe center point of the polygon. If not given, defaults to [0, 0].No
inscribedboolWhether the polygon is inscribed (true, the default) or circumscribed (false) about a circle with the specified radius.No
