hyperbolicFunction in std::sketch
Add a hyperbolic section to an existing sketch.
This is part of sketch v1 and is soft deprecated in favor of sketch-solve. Legacy sketch functions cannot be used with constraints; strongly prefer constraint-based sketch functions when possible. No constraint-based hyperbola is available yet; first try approximating the shape with one or more constrained arcs.
semiMajor | number(Length) | The semi major value, a, of the hyperbolic equation x^2 / a ^ 2 - y^2 / b^2 = 1. | Yes |
semiMinor | number(Length) | The semi minor value, b, of the hyperbolic equation x^2 / a ^ 2 - y^2 / b^2 = 1. | Yes |
interiorAbsolute | Point2d | Any point between the segment's start and end. Requires endAbsolute. Incompatible with interior or end. | No |
endAbsolute | Point2d | Where should this segment end? Requires interiorAbsolute. Incompatible with interior or end. | No |
interior | Point2d | Any point between the segment's start and end. This point is relative to the start point. Requires end. Incompatible with interiorAbsolute or endAbsolute. | No |
end | Point2d | Where should this segment end? This point is relative to the start point. Requires interior. Incompatible with interiorAbsolute or endAbsolute. | No |
tag | TagDecl | Create a new tag which refers to this arc. | No |
