gdt::angularityFunction in std::gdt
GD&T angularity annotation specifying how much faces or edges may deviate from an orientation at a basic angle relative to datum references.
Angularity is an orientation tolerance. The specified angle is a basic
dimension in the drawing or model geometry. The tolerance is a length
controlling the size of the zone, not an angular plus-or-minus value.
Provide at least one of faces or edges. Supplying both is allowed, but
omitting both is an error.
tolerance | number(Length) | The tolerance zone size for orientation at a basic angle. | Yes |
faces | [TaggedFace; 1+] | The faces to be annotated. At least one of faces or edges must be supplied. | No |
edges | [Edge or any; 1+] | The edges to be annotated. At least one of faces or edges must be supplied. | No |
datums | [string; 1+] | The datum references to display in the feature control frame. Supports up to primary, secondary, and tertiary datums. | No |
