Std Gear Herringbone
gear::herringboneFunction in std::gear
A herringbone gear (like a helical gear that reverses direction halfway up the axis)
The gear will be placed at (0, 0, 0) in the global scene, and extruded up the Z axis. Use translate() and rotate() to move it around once it's created.
nTeethnumber(_)A number.Yes
modulenumber(Length)A number.Yes
pressureAnglenumber(Angle)A number.Yes
gearHeightnumber(Length)A number.Yes
helixAnglenumber(Angle)A number.Yes
