conicFunction in std::sketch
Add a conic section to an existing sketch.
This is part of sketch v1 and is soft deprecated in favor of sketch-solve. Legacy sketch functions cannot be used with constraints; strongly prefer constraint-based sketch functions when possible. No constraint-based conic is available yet; first try approximating the shape with one or more constrained arcs.
interiorAbsolutePoint2dAny point between the segment's start and end. Requires endAbsolute. Incompatible with interior or end.No
endAbsolutePoint2dWhere should this segment end? Requires interiorAbsolute. Incompatible with interior or end.No
interiorPoint2dAny point between the segment's start and end. This point is relative to the start point. Requires end. Incompatible with interiorAbsolute or endAbsolute.No
endPoint2dWhere should this segment end? This point is relative to the start point. Requires interior. Incompatible with interiorAbsolute or endAbsolute.No
coefficients[number; 6]The coefficients [a, b, c, d, e, f] of the generic conic equation ax^2 + by^2 + cxy + dx + ey + f = 0. If provided the start and end tangents will be calculated using this equation. Incompatible with startTangent and endTangent.No
startTangentPoint2dThe tangent of the conic section at the start. If not provided the tangent of the previous path segment is used. Incompatible with coefficients.No
endTangentPoint2dThe tangent of the conic section at the end. Incompatible with coefficients.No
tagTagDeclCreate a new tag which refers to this segment.No
