gdt::note
gdt::noteFunction in std::gdt
GD&T note for adding free-floating manufacturing text that is not attached to a face or edge.
This is part of model-based definition (MBD). Unlike gdt::annotation, a note has no leader and is placed directly on a plane. By default it lives on the world XY plane, but any plane (a standard plane like XZ/YZ, or a user-defined plane) can be supplied via framePlane.
notestringThe note text to display.Yes
framePlanePlaneThe plane the note lies in. The default is XY. Other standard planes like XZ and YZ, or a user-defined plane, can also be used.No
framePositionPoint2dThe 2D position of the note within the plane, in the plane's local coordinates. The default is [100mm, 100mm].No
fontSizenumber(Length)The model-space height to use for the note text. The default is 10mm. Explicit units are supported; bare numbers use the file's default length unit. This changes the scene size, not the internal raster texture quality.No
annotationNamestringHuman-friendly name for this annotation in exports and model metadata. This is not displayed visually.No
GdtAnnotation - A GD&T annotation created by one of the gdt functions.
Rendered example of gdt::note 0
Rendered example of gdt::note 1
