gdt::profileFunction in std::gdt
GD&T profile annotation specifying how much edges or faces may deviate from their ideal shape.
gdt::profile is kept for backwards compatibility with existing KCL programs.
For new code, prefer gdt::profileLine when annotating edges and
gdt::profileSurface when annotating faces.
Provide exactly one of edges or faces. Passing edges delegates to
profileLine; passing faces delegates to profileSurface. Passing both,
or neither, is a KCL error.
tolerance | number(Length) | The amount of deviation from an ideal profile that is acceptable. | Yes |
edges | [Edge or any; 1+] | The edges to be annotated with profile of a line. Provide either edges or faces, but not both. | No |
faces | [TaggedFace; 1+] | The faces to be annotated with profile of a surface. Provide either edges or faces, but not both. | No |
datums | [string; 1+] | The datum references to display in the feature control frame. Supports up to primary, secondary, and tertiary datums. | No |
