ellipticFunction in std::sketch
Add an elliptic section to an existing sketch.
This is part of sketch v1 and is soft deprecated in favor of sketch-solve. Legacy sketch functions cannot be used with constraints; strongly prefer constraint-based sketch functions when possible. No constraint-based elliptic curve is available yet; first try approximating the shape with one or more constrained arcs.
center | Point2d | The center of the ellipse. | Yes |
angleStart | number(Angle) | Where along the ellptic should this segment start? | Yes |
angleEnd | number(Angle) | Where along the ellptic should this segment end? | Yes |
minorRadius | number(Length) | The minor radius, b, of the elliptic equation x^2 / a^2 + y^2 / b^2 = 1. | Yes |
majorRadius | number(Length) | The major radius, a, of the elliptic equation x^2 / a^2 + y^2 / b^2 = 1. Equivalent to majorAxis = [majorRadius, 0]. | No |
majorAxis | Point2d | The major axis of the elliptic. | No |
tag | TagDecl | Create a new tag which refers to this arc. | No |
