filletFunction in std::solid
Blend a transitional edge along a tagged path, smoothing the sharp edge.
Fillet is similar in function and use to a chamfer, except a chamfer will cut a sharp transition along an edge while fillet will smoothly blend the transition.
Face references
In edges, sideFaces and endFaces contain face tags or face UUIDs, not raw sketch segments. For a side face created by extruding profile.line1, use profileRegion.tags.line1 or body.sketch.tags.line1, where profileRegion is the extruded region and body is the resulting solid. For extrusion caps, declare tagStart = $startCap or tagEnd = $endCap, then refer to startCap or endCap. Use $ only when declaring the tag. See Face API Edge References for selection examples.
solidSolidThe solid whose edges should be fillettedYes
radiusnumber(Length)The radius of the filletYes
tags[Edge; 1+]The paths you want to fillet (legacy API)No
edges[any]Preferred for KCL 3. Required unless legacy tags is provided. Do not provide both. Array of edge references; each element is an object with: - sideFaces: array of one or more face tags or face UUIDs. Adjacent faces that share the edge(s) to fillet. - endFaces?: array of face tags or face UUIDs. Optional faces to disambiguate when multiple edges share the same two faces. - index?: number(Count). Optional index when multiple edges share the same faces (0-based).No
tagTagDeclCreate a new tag which refers to this fillet. For multiple edges, omit tag or tag each edge in a separate call.No
legacyMethodboolDeprecated as of KCL 2.0. Removed in KCL 3.0. You probably shouldn't set this or care about this, it's for opting back into an older version of an engine algorithm. If true, revert to older engine SSI algorithm. Defaults to false.No
versionnumber(_)Removed in KCL 3.0. Experimental. What version of the fillet algorithm to use. 0 means "let the Zoo engine choose whichever version is best", 1 is the original Zoo fillet algorithm, 2 is the newer algorithm (supports rolling ball fillets). On KCL 2.0 and before, the default is 1. Use KCL 3.0 or later for the newest algorithm without setting version. edges does not require version = 2.No
tangentChainboolAdded in KCL 3.0. If true, also fillet edges that are tangent to the selected edges. Defaults to true.No
