solver::distanceFunction in std::solver
Constrain the distance between two sketch entities.
The distance is always non-negative, and the order of the two entities
does not matter: distance([a, b]) == 5mm and distance([b, a]) == 5mm
are the same constraint. This differs from horizontalDistance and
verticalDistance, which are signed and order-sensitive.
Supported entity pairs (in either order):
- Two points: the straight-line distance between them.
- Point and line: the perpendicular distance from the point to the infinite line through the line segment.
- Two lines: constrains the lines to be parallel and separated by the given perpendicular distance.
- Point and circle: the gap between the point and the nearest point on the circle's perimeter, with the point kept outside the circle.
- Line and circle: the gap between the circle's perimeter and the infinite line through the line segment, with the circle kept to one side of the line.
- Two circles: the gap between the two perimeters, with each circle kept outside the other.
A point may be ORIGIN, and arcs are treated as the full circle through
them.
points | [Segment or Point2d; 2] | Two sketch entities, or one sketch entity and ORIGIN, whose separation should match the value set with ==. The order of the entities does not matter. | Yes |
labelPosition | Point2d | Optional position for the displayed constraint label in the sketch's local 2D coordinate system. | No |
