Std Solid Hollow
hollowFunction in std::solid
Make the inside of a 3D object hollow.
Remove volume from a 3-dimensional shape such that a wall of the provided thickness remains around the exterior of the shape. By default, it'll look visually the same, but you can see the difference if you use appearance to make it transparent, or cut it open with a subtract.
solidSolidWhich solid to hollow outYes
thicknessnumber(Length)The thickness of the remaining shellYes
