Research
KCL: A Programming Language for Parametric CAD
Research by Adam Chalmers
1 Introducing KCL
The KittyCAD Programming Language (or just KCL) is a programming language, but a very unusual one. Most languages define digital artifacts like software. This language defines real-world artifacts, like gears and engines.
When you design a model in CAD software, clicking on various buttons and drawing out various shapes, the CAD software is constantly updating some hidden internal model, represented as a complicated series of 3D equations and algebraic relations. You, the user, never get to see or edit that model directly. You issue commands with the user interface, e.g. “sketch this square” or “sweep this circle along that path”, and the CAD software updates its internal model, then renders that model as a 3D visual on your screen. At the end of your session, you save or export your model, and the CAD software converts its hidden internal model into some file format that your filesystem can save. Maybe that file format can be read by other software, or maybe just by the one specific CAD suite you’re using.
Most CAD systems never show you their internal model. You can only change it (with your mouse and keyboard) and view a simplified 3D representation of it on your screen. Zoo is different. KCL is the fundamental model underpinning Zoo. If you want to know what the software truly knows about your model, just read the KCL. There’s no hidden information. It’s all there in the KCL.
2 Advantages of Text: Readability, Collaboration, and Automation
Existing CAD systems store their model as complex algebraic data that can’t be read by humans – not easily, and sometimes not at all, because it’s stored in binary instead of text. We knew we wanted Zoo to fundamentally store its CAD models as text, for a few reasons.
Text is readable. Humans cannot read binary data (except for that one weird kid who always came first in your CS program and was immediately hired by an unknown government agency upon graduating). People can’t just read a SolidWorks or OBJ file and keep a clear understanding of all the different parts being designed. But KCL is readable. Models are represented with human-friendly names like cube = extrude(square, 10) or chessboard = gridPattern([8, 8], tile). Sure, code can take a while to get used to, but this is much more readable than indecipherable binary data like 02357fa35bbc.
Text is collaborative. There’s already a huge ecosystem of software that lets you collaborate on text. You can collaborate in real-time over Google Docs, or asynchronously by sending each other Word documents with Track Changes showing revisions. You can add comments to other people’s text. And that’s just the beginning. Software engineers have spent decades understanding how to resolve conflicts in text editing. There’s a whole ecosystem of powerful tools that track and resolve conflicts when the same text is edited by multiple people. Generally these algorithms don’t work on binary data (or at least, not as well), and their results cannot be audited by humans because humans can’t read binary. Using text allows us to hook into the existing suite of text collaboration tools.
Text is machine-readable and machine-produceable. The LLM and AI economy is all anyone can talk about right now, which is not necessarily good. A lot of LLM applications are being massively overhyped. Nobody needs an AI-powered mouse or toaster. But behind the hype lies a genuine huge advance in text processing algorithms. The research behind LLMs has made it easier than ever to let machines read and comprehend human text, and generate their own text in response. You don’t have to buy into AI hype to see that computers ability to read and write English has massively advanced over the last several years. By representing geometry as text, KCL can reuse the rapidly-growing ecosystem of machine text tools – LLMS, summarizers, AI coding assistants, etc. This means LLMs can generate KCL from a human prompt, explain the purpose behind some line of code, or improve your KCL code for you. Currently AI language models are far, far ahead of AI graphical models, or binary models, or specialized models trained on the specifics of other file formats. By storing 3D designs as text rather than binary, KCL ironically lets these applications understand geometry better than storing it in a traditional 3D file.
So, we felt confident that Zoo fundamentally needed to use text as its model. But there are many text formats that aren’t full programming languages. Why must Zoo store its model specifically as code?
3 Advantages of Code: Parametricity and Reusability
Code solves two big problems with traditional CAD suites: representing parametricity and reusing common components.
Code is inherently parametric. Software engineers don’t just write a program as a big list of instructions from top to bottom. They break code into several reusable functions that solve a problem. Similarly, top-tier mechanical designers don’t tend to model a gear with its pitch diameter and pressure angle included as static, 'magic' values in their CAD system. Instead, they design a gear which is defined by some parameters; for example, its module (or diametrical pitch), its pressure angle, and its number of teeth. That way, when the system requirements change, the engineer can adjust the design parameters and watch as their parameters feed through their parameterized calculations, and the rest of their gear design reflows to meet this new constraint.
This is doable but somewhat awkward in existing CAD products. It’s difficult to tell which dimensions are driving the design and which are driven by it. It’s hard to know where the model will break when parameters are varied. On the other hand, code is a natural fit for parametric design. When you break your code into functions, those functions are inherently parametric – that’s why they accept parameters! A function like gear(module, nTeeth, aPressure) obviously declares which parameters it accepts. Comments and documentation explain what each parameter is and how it’s used — serving to capture design intent in a way that is not readily achievable with traditional CAD workflows. Constants can be defined once, at the top of a file, and used as parameters into many different parts. Parametric functions can easily call other parametric functions and pass through their constants.
For example, a designer building a server rack could define constants for both the height of a server rack, and the number of server sleds. Then the height of each server rack can be easily calculated (i.e. totalHeight / numSleds). The function for designing a single server sled would accept this height as a parameter. Then when the total height of the rack changes, or the number of sleds changes, the model is easily recalculated. Designers can clearly trace these constants and visually follow them throughout the code, seeing where they’re calculated and how they’re used by other functions.
Code enables efficient reuse. In the example above, each server rack is a copy of the others. If you have 20 servers in a server rack, and each server has 8 memory sticks, and each memory stick has 8 controllers, then you have 1280 total memory controllers in your model. The more complex your model becomes, the slower it is to use. It would be very wasteful for CAD software to just copy this controller 1280 times – the user’s computer would need to hold all 1280 copies in its limited GPU, CPU and memory. Instead, most software would notice that the controller unit is repeated, and only store 1 copy of it. It would tag the remaining 1279 as just a copy, and efficiently reuse the original. This is called “instancing” and it’s a powerful technique to make large, complex models without slowing down the user’s computer.
Unfortunately, instancing is difficult. In CAD it’s hard to know when two things are exactly copies of each other. Even when CAD software can do instancing properly, usually the file formats you save or export to won’t understand instancing. So when you save your file, it has to write out 1280 copies of that memory controller, and then load them all back in when you next open the software. This frustrates engineers to no end. Waiting an hour for your file to load is unacceptable.
In contrast, in a functional programming language it’s always clear when a calculation can be reused. Functions called with the same inputs will produce the same outputs. So whenever you call server(height), as long as its parameters are the same, the output will be the same. This will allow Zoo to efficiently cache and reuse parts of models. Right now we haven’t actually implemented this, but we’ve architected it to make it easy in the future.
By storing Zoo files as text, Zoo enables engineers to collaborate and understand what their models actually are. Programmable code lets you break down complicated models into smaller, simpler parts and reuse them efficiently. This is why we built KCL.
4 Current Implementation and Workflow
KCL is available now in our Zoo app and our command-line tool. You can use KCL to define geometry for your models. The typical workflow is:
  • Make a single part
    • Use your mouse to start a sketch on some plane, dragging lines around with our interactive visual editor and constraint solver.
    • This generates KCL code, which you can view
    • Turn those 2D sketches into 3D solids with point-and-click tools like Extrude, Revolve, Sweep, and apply fillets to them
  • Assemble a larger part
    • Move your single part into a function, and identify which constants should really be parameters
    • Rephrase your specific part into a parametric part
    • Call the function with different parameters, or start new parts
KCL has a standard library with common geometry tools like various kinds of lines, or operations on 2D and 3D geometry like Revolve and Fillet and Pattern. It supports familiar 2D constraints, like constraining two lines to be parallel, or equal length, or tangent to an arc. This uses a novel 2D constraint solver, which we've made open-source for general public usage. It also has the standard math tools from normal programming, so you don’t need a calculator open in another window. All your calculations can be written in KCL. To check your work, view each constant’s value in the Variables pane, or use an assert statement to ensure an error gets printed if your math was wrong.
5 Core Design Principles
KCL is a functional programming language because we believe existing programming languages are ill-suited to representing 3D geometry. Rather than reacting to changes or slowly updating a model as changes occur, KCL just defines your geometry. Variables are not updated or looped over. Instead, use higher-level features like patterns to replicate your geometry. This enables more powerful IDE features (like clicking on an edge in your 3D viewer to highlight the exact location in the code that defined that edge). In the future, it will allow us to efficiently reuse calculations instead of redoing them.
6 Current Limitations and Future Direction
KCL has several conflicting goals. It has to be easy and intuitive for mechanical engineers who haven’t coded much. But it has to be powerful enough to express complicated ideas from advanced programmers too. It’s difficult to serve both beginners and experts. We have a long way to go on making KCL friendlier to beginners in particular. We are excited to do user testing, find the pain points beginners experience, and tackle each one so that beginners have an easier time with KCL.
One limitation KCL has is that it does not properly support declaratively positioning 3D parts relative to each other. That's something we need to improve, because manually positioning parts for assemblies is a waste of valuable mechanical engineering time. We're actively working to extend KCL with a 3D constraint solver that works similarly to existing CAD software, allowing users to, say, constraint a bolt to be concentric with the hole it fits into, or ensuring that two faces on two different parts are mated together representing where they'll be welded together. This will allow engineers to spend less time manually positioning their parts in space, and more time designing.
