gdt::cylindricityFunction in std::gdt
GD&T annotation specifying how closely a feature must conform to a perfect cylinder.
Cylindricity is a form tolerance. It controls how much a cylindrical
surface may deviate from a perfect cylinder, combining roundness,
straightness, and taper into a single requirement. Every point on the
surface must lie between two coaxial cylinders whose radii differ by the
given tolerance. When applied to a round face, such as the wall of a
cylinder, the whole surface must meet that requirement. When applied to a
circular edge, that edge must lie within the same zone.
Cylindricity is a form tolerance, so it does not reference datums.
tolerance | number(Length) | The amount of deviation from a perfect cylinder that is acceptable. | Yes |
faces | [TaggedFace; 1+] | The faces to be annotated. | No |
edges | [Edge or any; 1+] | The edges to be annotated. | No |
