revolve
revolveFunction in std::sketch
Rotate a sketch around some provided axis, creating a solid from its extent.
This, like extrude, is able to create a 3-dimensional solid from a 2-dimensional sketch. However, unlike extrude, this creates a solid by using the extent of the sketch as its revolved around an axis rather than using the extent of the sketch linearly translated through a third dimension.
Revolve occurs around a local sketch axis rather than a global axis.
You can provide more than one sketch to revolve, and they will all be revolved around the same axis.
NOTE: Currently,, revolved bodies don't support being scaled in a non-uniform way (i.e. scaled differently along each axis).
sketches[Sketch or Segment; 1+]The sketch or set of sketches that should be revolved, or solved sketch segments for a surface revolve.Yes
axisAxis2d or Edge or Segment or anyAxis of revolution. Can be an Axis2d, an Edge, a solved Segment, or an edge reference object. Edge reference objects use sideFaces, e.g. { sideFaces = [faceTag1, faceTag2] }.Yes
anglenumber(Angle)Angle to revolve (in degrees). Default is 360.No
symmetricboolIf true, the extrusion will happen symmetrically around the sketch. Otherwise, the extrusion will happen on only one side of the sketch.No
bidirectionalAnglenumber(Angle)If specified, will also revolve in the opposite direction to 'angle' to the specified angle. If 'symmetric' is true, this value is ignored.No
tagStartTagDeclA named tag for the face at the start of the revolve, i.e. the original sketch.No
tagEndTagDeclA named tag for the face at the end of the revolve.No
bodyTypestringWhat type of body to produce (solid or surface). Defaults to "solid".No
[Solid; 1+]
