view::directedFunction in std::view
Create a camera view that looks along a custom direction.
Added in KCL 3.0.
The returned value stores intent, not resolved numbers: an argument you omit stays absent, and the consumer that activates the view resolves it against the model it is showing, so one view value is valid for any model.
direction and up set only directions: both are normalized when the
view is constructed, so their magnitudes carry no information and zoom
comes from distance. Each must be a non-zero vector, and they must not
be parallel or nearly parallel to each other; such arguments are errors.
Any angle above roughly 0.00006 degrees between the two is accepted, so
only vectors that are parallel to within a rounding error are rejected.
When that happens, choose an up that does not lie along direction.
Every argument you pass must be a finite number; an infinite or undefined value, such as one produced by dividing by zero, is an error rather than a stored value no consumer could use.
Lengths are recorded in millimeters whatever unit you write them in, so
distance = 2inch is stored as 50.8mm, and a target coordinate is
converted the same way. The view means the same thing either way; a tool
that reads the view back reports millimeters. direction and up carry
no unit at all, because only their ratio matters.
A distance is a separation, so it must be greater than zero. Zero would
put the camera on the point it looks at, and a negative value would put it
behind that point; both are errors rather than a camera nobody can
resolve. A target is a point, so its coordinates may be negative.
direction | Point3d | The direction the camera looks, from the camera toward the target. | Yes |
up | Point3d | The camera's up direction. When omitted, [0, 0, 1]: the positive Z axis, which is the modeling app's world up. | No |
target | Point3d | The point the camera looks at. When omitted, the view centers on the bounds of the model at activation. | No |
distance | number(Length) | The distance from the camera to the target. Must be greater than zero. When omitted, the view fits the model at activation. | No |
projection | Projection | The camera projection. When omitted, the view is orthographic, so the same file renders identically in every consumer. | No |
CameraView - A camera viewpoint, stored as intent: what the camera looks at and from which direction, not a snapshot of engine camera state.
