helixFunction in std
Create a helix.
revolutions | number(_) | Number of revolutions. | Yes |
angleStart | number(Angle) | Start angle. | Yes |
ccw | bool | Is the helix rotation counter clockwise? The default is false. | No |
radius | number(Length) | Radius of the helix. | No |
axis | Axis3d or Edge or Segment or any | Axis to use for the helix. Can be an Axis3d, an Edge, a Segment, or an edge reference object when not using a cylinder. Edge reference objects use sideFaces, e.g. { sideFaces = [faceTag1, faceTag2] }. | No |
length | number(Length) | Length of the helix. This is not necessary if the helix is created around an edge. If not given the length of the edge is used. | No |
cylinder | Solid | Cylinder to create the helix on. | No |
Helix - A helix.
