A ring gear (i.e. a gear with internal teeth).
The gear will be placed at (0, 0, 0) in the global scene, and extruded up the Z axis.
Use translate() and rotate() to move it around once it's created.
nTeeth | number(_) | A number. | Yes |
module | number(Length) | A number. | Yes |
pressureAngle | number(Angle) | A number. | Yes |
helixAngle | number(Angle) | A number. | Yes |
gearHeight | number(Length) | A number. | Yes |
