sweepFunction in std::sketch
Create a 3D surface or solid by sweeping a sketch along a path.
This, like extrude, is able to create a 3-dimensional surface or solid from a 2-dimensional sketch. However, unlike extrude, this creates a body by using the extent of the sketch as its path. This is useful for creating more complex shapes that can't be created with a simple extrusion.
You can provide more than one sketch to sweep, and they will all be swept along the same path.
sketches[Sketch or Face or TaggedFace or Segment; 1+]The sketch or set of sketches that should be swept in space.Yes
pathSketch or Helix or [Segment; 1+]The path to sweep the sketch along.Yes
sectionalboolIn KCL 2, if true, the sweep is broken up into sub-sweeps (extrusions, revolves, sweeps) based on the trajectory path components. Sectional sweeps are not supported in KCL 3, so this argument has no effect and produces a warning.No
relativeTostringDeprecated. Removed in KCL 3.0. Use 'translateProfileToPath' and 'orientProfilePerpendicular' instead. What is the sweep relative to? Can be either 'sketchPlane' or 'trajectoryCurve'.No
translateProfileToPathboolIf true, the profile being swept will be moved to the path being swept along, before the sweep starts. If false, the profile stays where it is, and the sweep starts from there. Defaults to false. On KCL 2.0 and earlier, explicitly setting this option, even to false, requires version = 2.No
orientProfilePerpendicularboolIf true, before the sweep starts, the profile will be re-oriented so that it is perpendicular to the path being swept along. If false, the profile is left in its current orientation. On KCL 2.0 and earlier, defaults to false. On KCL 3.0 and later, defaults to the value of translateProfileToPath, so a profile that is moved to the path is also oriented perpendicular to it unless you say otherwise. On KCL 2.0 and earlier, explicitly setting this option, even to false, requires version = 2.No
tagStartTagDeclA named tag for the face at the start of the sweep, i.e. the original sketch.No
tagEndTagDeclA named tag for the face at the end of the sweep.No
bodyTypestringWhat type of body to produce (solid or surface). Defaults to "solid".No
versionnumber(_)Removed in KCL 3.0. What version of the sweeping algorithm to use. 0 means "let the Zoo engine choose whichever version is best", 1 is the original Zoo sweep algorithm, 2 is the newer algorithm. On KCL 2.0 and earlier, the default is 0. KCL 3.0 and later always use the newest algorithm.No
[Solid; 1+]
