gdt::runoutFunction in std::gdt
GD&T annotation specifying circular runout relative to a datum axis.
Runout controls how much a round feature may vary as it rotates around a referenced datum axis. It may be applied to circular edges or round faces, such as the wall of a cylinder. Datum references are required.
Runout is applied regardless of feature size and does not use MMC or LMC.
tolerance | number(Length) | The circular runout relative to the datum axis that is acceptable. | Yes |
datums | [string; 1+] | The datum references to display in the feature control frame. Supports up to primary, secondary, and tertiary datums. | Yes |
faces | [TaggedFace; 1+] | The faces to be annotated. | No |
edges | [Edge or any; 1+] | The edges to be annotated. | No |
