angledLineThatIntersects
angledLineThatIntersectsFunction in std::sketch
Draw an angled line from the current origin, constructing a line segment such that the newly created line intersects the desired target line segment.
This is part of sketch v1 and is deprecated in favor of sketch-solve. Legacy sketch functions cannot be used with constraints; strongly prefer solver::line with angle and coincident constraints inside a sketch block instead.
anglenumber(Angle)Which angle should the line be drawn at?Yes
intersectTagTaggedEdgeThe tag of the line to intersect with.Yes
offsetnumber(Length)The offset from the intersecting line.No
