gdt::flatnessFunction in std::gdt
GD&T annotation specifying how flat faces should be.
faces | [TaggedFace; 1+] | The faces to be annotated. | Yes |
tolerance | number(Length) | The amount of deviation from a perfect plane that is acceptable. | Yes |
