circleFunction in std::sketch
Construct a 2-dimensional circle, of the specified radius, centered at the provided (x, y) origin point.
This is part of sketch v1 and is deprecated. Legacy sketch functions cannot
be used with constraints. Strongly prefer constraint-based sketch functions:
in KCL 2, create a
solver::circle inside a
sketch block, then select the
closed profile with region.
Legacy KCL 1 example: The next example uses deprecated subtract2d.
sketchOrSurface | Sketch or Plane or Face | Sketch to extend, or plane or surface to sketch on. | Yes |
center | Point2d | The center of the circle. If not given, defaults to [0, 0]. | No |
radius | number(Length) | The radius of the circle. Incompatible with diameter. | No |
diameter | number(Length) | The diameter of the circle. Incompatible with radius. | No |
tag | TagDecl | Create a new tag which refers to this circle. | No |
