gdt::positionFunction in std::gdt
GD&T position annotation specifying how much faces or edges may deviate from their ideal location.
tolerance | number(Length) | The positional tolerance that is acceptable. | Yes |
faces | [TaggedFace; 1+] | The faces to be annotated. | No |
edges | [Edge or any; 1+] | The edges to be annotated. | No |
datums | [string; 1+] | The datum references to display in the feature control frame. Supports up to primary, secondary, and tertiary datums. | No |
