offsetPlaneFunction in std
Offset a plane by a distance along its normal.
For example, if you offset the XZ plane by 10, the new plane will be parallel to the XZ
plane and 10 units away from it.
plane | Plane | The plane (e.g. XY) which this new plane is created from. | Yes |
offset | number(Length) | Distance from the standard plane this new plane will be created at. | Yes |
Plane - An abstract plane.
