legLen
legLenFunction in std::math
Compute the length of the given leg.
hypotenusenumber(Length)The length of the triangle's hypotenuse.Yes
legnumber(Length)The length of one of the triangle's legs (i.e. non-hypotenuse side).Yes
number(Length) - A number.
