exitFunction in std::runtime
Exit the program early.
Exiting early can be helpful to see the intermediate output of a program to
help debug. Remember to always remove the call to exit() after debugging
is complete.
When exit() is used in an imported module, only the imported module exits
early. Because imported modules execute concurrently, exit() in one module
does not affect other modules.
On the other hand, if you import a function from another module, and that
function calls exit(), then calling the function exits the caller.
