patternCircular3d
patternCircular3dFunction in std::solid
Repeat a 3-dimensional body or imported geometry some number of times along a partial or complete circle some specified number of times. Each object may additionally be rotated along the circle, ensuring orientation of the solid with respect to the center of the circle is maintained.
solids[Solid; 1+] or ImportedGeometryThe solid(s) or imported geometry to pattern.Yes
instancesnumber(_)The number of total instances. Must be greater than or equal to 1. This includes the original entity. For example, if instances is 2, there will be two copies -- the original, and one new copy. If instances is 1, this has no effect.Yes
axisAxis3d or Point3dThe axis of the pattern. A 3D vector.Yes
centerPoint3dThe center about which to make the pattern. This is a 3D vector. If not given, defaults to [0, 0, 0].No
arcDegreesnumber(deg)"The arc angle to place the repetitions. Must be greater than 0.No
rotateDuplicatesboolWhether or not to rotate the duplicates as they are copied.No
useOriginalboolIf the target was sketched on an extrusion, setting this will use the original sketch as the target, not the entire joined solid.No
[Solid or ImportedGeometry; 1+]
