subtract2dFunction in std::sketch
Use a 2-dimensional sketch to cut a hole in another 2-dimensional sketch.
This is part of sketch v1 and is deprecated. Legacy sketch functions cannot
be used with constraints. Strongly prefer constraint-based sketch functions:
in KCL 2, construct the outer
boundary and hole as segments inside a
sketch block, then select the
required bounded face with
region.
tool | [Sketch; 1+] | The shape(s) which should be cut out of the sketch. | Yes |
