Create a circle in a sketch. The circle segment always has a starting point and sweeps counterclockwise from it.
start | Point2d | A point on the circle that sets where the circle starts. | Yes |
center | Point2d | The center of the circle. | Yes |
construction | bool | Whether this segment is construction geometry rather than part of the modeled profile. | No |
Segment - A segment in a sketch created in a sketch block. It may be a line, arc, point, or other segment type.
