    • KCL Book
        • sketch2::angle
        • sketch2::arc
        • sketch2::coincident
        • sketch2::diameter
        • sketch2::distance
        • sketch2::equalLength
        • sketch2::horizontal
        • sketch2::horizontalDistance
        • sketch2::line
        • sketch2::parallel
        • sketch2::perpendicular
        • sketch2::point
        • sketch2::radius
        • sketch2::region
        • sketch2::tangent
        • sketch2::vertical
        • sketch2::verticalDistance
        • sketch2
sketch2::parallel
sketch2::parallelFunction in std::sketch2
Constrain lines to be parallel.
Currently limited to two lines.
input[Segment; 2+]Yes
