    • KCL Book
        • sketch2::angle
        • sketch2::arc
        • sketch2::coincident
        • sketch2::diameter
        • sketch2::distance
        • sketch2::equalLength
        • sketch2::horizontal
        • sketch2::horizontalDistance
        • sketch2::line
        • sketch2::parallel
        • sketch2::perpendicular
        • sketch2::point
        • sketch2::radius
        • sketch2::region
        • sketch2::tangent
        • sketch2::vertical
        • sketch2::verticalDistance
        • sketch2
sketch2::point
sketch2::pointFunction in std::sketch2
atPoint2dA point in two dimensional space.Yes
Segment - A segment of a path in a sketch. It may be a line, arc, or other segment type.
