Constrain the diameter of an arc or circle segment. Accepts a single arc or circle segment and constrains the distance from its center to its start point. Note: Diameter uses the same solver constraint as radius (distance between two points), but is stored as a separate constraint type for proper UI display.
points | Segment | A segment of a path in a sketch. It may be a line, arc, or other segment type. | Yes |
