    • KCL Book
        • sketch2::angle
        • sketch2::arc
        • sketch2::coincident
        • sketch2::diameter
        • sketch2::distance
        • sketch2::equalLength
        • sketch2::horizontal
        • sketch2::horizontalDistance
        • sketch2::line
        • sketch2::parallel
        • sketch2::perpendicular
        • sketch2::point
        • sketch2::radius
        • sketch2::region
        • sketch2::tangent
        • sketch2::vertical
        • sketch2::verticalDistance
        • sketch2
        • sketch2::ORIGIN
Consts
sketch2::ORIGIN
sketch2::ORIGINConstant in std::sketch2
WARNING: This constant is experimental and may change or be removed.
The origin point in a sketch.
Type
Point2d - A point in two dimensional space.
