split-washer-flat-version
Fasteners
A flat split washer — also known as a spring lock washer — is a small metal ring with a gap in it. It's usually placed under a nut or bolt head to stop it from loosening when things vibrate. Normally, this washer is springy and twisted, but for simplicity, we’re making a flat version.
Zookeeper is here!
