CAD Samples Gallery
herringbone-planetary-gearset
AutomotiveAerospace
A herringbone planetary gearset is a type of planetary gear system where the teeth of the sun gear, planet gears, and/or ring gear are herringbone rather than straight. This design allows for smoother, quieter operation, greater load-carrying capacity, and more flexible shaft alignment.
Zookeeper is here!
