cold-plate
AutomotiveAerospaceComputer Hardware
A cold plate is a thermal management device used to remove heat from a device or component, typically by transferring heat to a liquid coolant that flows through the plate. It's a conductive cooling solution, commonly made of materials like aluminum or copper, with internal channels or tubes for the coolant
cold-plate
Zookeeper is here!
